Solved Re-install a V20 portal
stasmour
Greetings! I recently installed a pro 8sc hosted sub for a customer of mine. After finishing the installation guide the dashboard appeard and everything was fine. Afterwards i realised i wanted to change some things like the number on the extensions from 4digits to 2digits(1000 to 10). Is there any way that i can rerun the installation guide? Thanks
No you will have to do a reinstall.
You can stop the machine in the portal, then rerun the installer by clicking switch to hosted again and restarting. This will redo everything from the beginning. If you havent released the FQDN it will just reuse what you had previously selected.
Reactions: rayfield
Thank you that was it! You are awesome!!
  • Love
Reactions: NicholasP_3CX
