Re-Installation of a 3CX V20 NFR License
gregory.b
Hello I have a question.
I have a 3CX in Version 20 with an NFR Enterprise license.
This 3CX consumed way too much resources on my Server. Thus, i want to reinstalled as brand new.
How can I do it knowing that it was said that the License is only compatible with V20.
I want to do the reinstallation from Scratch, reconfigurer each much by itself without any backup.
How can I do it.
Idea
If i installed a brand new 3CX with V18 then Upgrade the same to V20 and do a license Swap from Free to NFR will it WORK ????
Also Will the FQDN of the NFR license follow with the SWAP ( This would be great )
Can you please advise.
Simply go to customer.3cx.com and click "Deploy" or "install" (Forget which) on your key. Generate your installation file and install via the ISO. This will install a blank 3CX v20.
Hello, Thank you for your quick reply I will Try this
However,
what about the FQDN and license will it stay the Same
However,
Yes FQDN is bound to the license.
Reactions: gregory.b
tom.walker@blackcountryra
