Re-provision SBC
neil_HRC
Hi, maybe cant see the wood for the trees here but would someone kindly point me in the right direction on how to re-provision an existing Pi SBC to point to a new 3CX instance?
Thanks,
Neil
Code:
sudo apt remove 3cxsbc --purge
Code:
wget https://downloads-global.3cx.com/downloads/misc/d10pi.zip; sudo bash d10pi.zip
Thanks for the reply!
Ok, so process is to remove the package then reinstall right? Rather than modify a config file with new provisioning URL and AUTH key?
Also note the URL is slightly different to the official docs URL of:
Code:
wget https://downloads-global.3cx.com/downloads/sbc/3cxsbc.zip -O- | sudo bash
Just checking!
Senergia
