Reboot nginx service will not restart. V20
Greg W
I had to do a system restore after PC crash. We are running on Windows 10Pro and v20 3cx. The PC did updates during the night and restarted and since then nginx service will not start. I have done everything that I know to get it backup. I am not able to login to the management consul. The system did run for a day with no issues.
Try looking in the /log/nginx folder.
otherwise, event logs.
might be quicker for you to reinstall and restore.
what else are you running on that computer?
There is nothing else running on the PC. I may just reinstall but use the Debian ISO
Thanks for the info and advise. I landed up completely redoing the whole PC OS and then loading 3CX.
tom.walker@blackcountryra
