recommendation for a fax adapter?
Song
Anyone know of reliable fax adapter for the fax machine to fax out? Currently the 3cx is hosted in the cloud. So we cannot get a patton smartnode fxs adapter because the 3cx is not onsite. So I was wondering what do you guys recommend or will work with 3cx cloud hosted? Or is it better to get a standalone fax adapter, like the obi300? will that work?
Please share your experience what is the best and easy way to accomplish this to save some money on a analog line.
thank you.
i think the cisco spa 112 2 port phone adapter i the way to go..
Grandstream ATA 4FX ports
3CX does not support remote Fax extensions unless you are planning on using VPN. From some posts I've see you may be able to get it working using a "regular" extension. Faxing over VoIP is very fickle, I hope it works for you.
Patton Smartnode 4141 2 JS probably best to stay supported by 3CX:
https://www.3cx.com/voip-gateways/
As of the latest Alpha/Beta this model is also supported across SBC to the cloud however my opinion is stick to VPN if this is an off-premise solution.
[email protected].
