Recommended drive size for 45 Voicemail boxes!
MaxH
What is the recommended drive size for 45 user Voicemail boxes? We're not currently interested in call recording.
Thanks.
It would really depend on retention time. If they check their email on a regular basis, and everyone (most users) delete the voicemail after listing to it, then unless (perhaps) you are going cheap with a 120Gb SSD, it shouldn't be an issue. Even with a drive that small, I'm not sure you'd run into a problem. The price of an SSD has dropped so much recently (120Gb =~$19 US). I wouldn't consider buying anything smaller than a 500 Gb.
Keep in mind that when doing a backup, and also backing up voicemails, which your users will thank you for if your system crashes, your backup storage space will need to be larger too.
You could start with a smaller drive, if you have one on hand already , keep an eye on it, then if you find it filling up, clone it onto a larger drive.
Reactions: MaxH
Much appreciated. Thanks. I will swap out the Samsung 250GB SSD for the 500GB version.
[email protected].
