- Joined
- Mar 24, 2020
- Messages
- 45
- Reaction score
- 13
OK. I know that to record calls to a cell phone, I have to create an extension where the cell number is setup as the "Mobile" number and set that extension to "Ring my mobile simultaneously."
I have a setup in a doctors office where there is one extension set to always answer the phone. We call that extension the inbound call router. There is no actual phone connected to that extension, but several PCs in the office have the 3CX app open to that extension so they can change whare the calls go. When the inbound call router is set to "Available," calls go to the standard ring group of receptionist phones in the office. When the call router extension is set to "Do not disturb" it forwards calls to the cell phone of one of the business managers. This is usually done after hours so the business manager gets any after hours calls on her cell phone. They now want to be able to record these after hours calls.
I upgraded the client to the Enterprise license, so recording is now possible. I created a new extension called "Away" that doesn't have a phone connected to it. I set that Away extension to "Available," set up the business managers cell phone as the Mobile Number, and checked all the boxes for "Ring my mobile simultaneously," "Accept multiple calls," "Log out from Queues," "Accept calls from ring groups," and "Accept push notifications."
When I set the inbound call router extension to "Away." it is now set to forward calls to the new Away extension, and the mobile phone of the Away should ring simultaneously. That's not happening. Instead, it follows the rule set if the Away extension is unregistered. Even though I do not have a phone connected to that extension, it shows up as Green in the list of extensions - which I thought meant that it was registered. I then opened a 3cx App on my PC that is set to the Away extension. It is set to "Available." Now the call gets forwarded from the inbound call router to the Away extension, and i's 3cx app rings on my PC - But it still does not ring on the cell phone.
Before I write an entire novel, does anybody know why the cell phone isnt ringing whether or not I have the 3cx app for the Away extension on or off? Or have a better suggestion to get this to work? Thanks!
