Recordings Backup Incrementally?
Vince19
Hi all,
Would just like to find out, we have a few high-profile clients running 3cx Pro or higher and want to move their recordings offsite.
We already have a backup for the config via sftp set up.
If we include recordings (100GB+) will it back up incrementally or does it backup 100GB+ every time?
Thanks in advance,
I believe the backup does not include archive recordings, just local recordings. You need to backup archives recording via another solution
Hi, thanks for the answer, we are not making use of the remote Archiving at the moment, so i only have a bunch of local recordings. My Question is does the backup run incrementally or does it do a full backup every time?
Full backup
Reactions: Vince19
Edvard
