Reinstall 3CX on Debian Failover Server Without Triggering DNS Change
Wendelspanswick
We have our main server with UKFast and the failover server on AWS Lightsail, the problem is that I used PBX Express to install 3CX for the failover server and it used a different HTTPS port, 443 instead of 5001.
I need to do a manual reinstall on the failover server, how do I do this without triggering a DNS change as I don't want to have to restart the services on the main server as it will reset the wallboards, drop queue calls and ring backs.
Plan is to take a back up the failover server with Licence and FQDN - Best location for back up???
apt-get remove 3cxpbx
apt-get remove --purge 3cxpbx
Then
wget -O- http://downloads-global.3cx.com/downloads/3cxpbx/public.key | apt-key add -
echo "deb http://downloads-global.3cx.com/downloads/debian stretch main" | tee /etc/apt/sources.list.d/3cxpbx.list
apt-get update
apt-get install 3cxpbx
apt-get install net-tools
Restore from backup.
My guess is that the failover server will start with all services running and it will trigger a DNS change from the main server, which will mean I have to edit the licence on the main server then restart the services.
Hello @Wendelspanswick
Since the failover server will be installed after the main server the DNS change cannot be avoided as the failover server will need to contact the activation server during setup and therefore trigger the change. After the server is installed you can trigger another change to point the DNS to the original server by restarting the system service of the PBX.
You can use Google drive to store the backup or you can download it after it is complete to your machine.
Reactions: Wendelspanswick
Thank you, I was hoping to do it during working hours but it look's like a late night for me!
jmarshall
