RELEASE FQDN
dcorazon
I have a 3CX server and i want to change the FQDN but i doesn't find where to release the OLD FQDN from the licence key. Can somebody help
Hi @dcorazon, please note that the FQDN is set during the installation process only.
In order to change the FQDN you will need to do the following:
  • Take a backup without the license key information and fqdn
  • Uninstall the pbx
  • Access to the user portal with the email that was used to register the subscription
  • Go to my systems --- edit the subscription --- from there you can release the fqdn
  • Once done you can install again, enter the subscription and you will be able to set a new fqdn
Have a great day!
Sorry for the late. It's OK.
Reactions: Alejandro_3CX
Alright, good to know it worked.
Have a good one!
mazet
