Release FQDN
Ravilla
Hi All,
After release FQDN from free edition can i immediately add commercial license to that FQDN or it required time to release from the old one?
Thanks for advise
When it is released it is available right away. However you don't even need to go that route. You can give your free key code to your reseller of choice when making the purchase and they can upgrade it to the paid version and you for the same price. Then your free 3cx becomes a paid one and you don't have to reconfigure or re-install anything.
Reactions: YiannisH_3CX
Hi CentrexJ,
if can upgrade like this is very good.
is that possible?
Easily done. When you place your order give them the license key you have and tell them you want the key upgraded to the paid edition of your choice.
How many simultaneous calls, what flavor (std/pro/enterprise) and what license option (annual/perpetual) are you looking for?
Reactions: Ravilla
Yes CentrexJ is correct. The free license can be upgraded to a paid license without releasing/renewing. You just give your key to your reseller and 3CX upgrades it to the paid license type. The 3CX instance will then phone home and see the correct call count/feature set.
Reactions: Ravilla
As stated above you can upgrade your key to a commercial version without the need for a re-install. Once the upgrade is complete click on the "Refresh Licence Key Information"
johnblackwood1
