John, the outside ip changed and is not reconnecting the ext.Hi Curt,
You don't really need to do anything at all here, the system works fine with DHCP based phones.
Just for clarity though, is there any reason you through this was necessary?
Yes the phone wan, new addy not blacklisted.What IP has changed the wan IP address of the 3cx server or the wan IP address of the phone.
If the phone wan IP address has changed, there is nothing to do - I would check the blacklist.
If you 3CX wan ip address has changed, you need to go into Settings - Network Settings, and change your external IP Configuration
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
