Remote URL
2024ehf
Hello. I am using it on Windows 10 and i can not acces it Remotely only localy
https://1985.3cx.eu/
How can i fix it?
What shut i look at regading it? I am trying to access it remotly.
Fixed. Did not open port 443
I suggest running the firewall checker to ensure everything passes. Note that will stop 3CX services during the test.
Now it only givese me this error
  • detecting SIP ALG... detected (received e6fb1d53 ≠ c6d197dc) (How to resolve?)
Click that link, but overall you should disable SIP ALG on your router/firewall.
I have checkt it and can not find it on my routher
I have
Xiaomi Mesh System AX3000
And i can not find it
If their tech support can't help you disable it, you may need a different router.
This is related with your firewall configuration.
In any case you need to disable SIP ALG as this can cause several issues.
Check this guideline to identify the issue.
I know i have read this. I have Xiaomi Mesh System AX3000 and i have not found this settings in that routher.
You need to clarify this with the vendor documentation.
I have contacted xomi about this. Just waiting for replay from them.
Let us know the outcome.
In any case you need SIP ALG to be disabled.
Xomi told me it can not be done on my routher so i need to get a new routher.
Yes most probably. Try and let us know the outcome.
ARKC
