Remove spaces when importing mobile phone from Entra ID
rduarte
Hi there,
As can be seen here:
"Phone numbers must be provided in the format +CountryCode PhoneNumber, for example, +1 4251234567. There must be a space between the country/region code and the phone number."
https://learn.microsoft.com/en-us/entra/identity/authentication/concept-authentication-phone-options
Entra ID requires mobile phones to be entered as +country space number, otherwise they get rejected.
Not removing the spaces when importing them from Entra makes forward to my mobile not possible.
And even if the users corrects the phone number in the 3CX interface it gets back to the broken one after sync occurs.
Reactions: narkuma
Same problem here. Number should be cleaned to 3cx-format when synced.
tom.walker@blackcountryra
