Solved Rename status
rayt
Hi all,
I have a new client on SMB Pro and I need to rename the 2 customisable statuses. I can't seem to find this.
Is it not possible on SMB Pro or am I just not looking in the right place?
Thanks.
Hi there.
Customization of those options are not there on Free/SMB instances in the Setting of the System, as they are not there. Those settings are now in the profile settings of the user.
Reactions: rayt
Hello @rayt ,
If you navigate to the Web Client > Settings > Call Forwarding > Lunch or Bussiness Trip and you will be able to rename the Status name of these statuses.
You can do so also by navigating to Admin > Users > select user > Call Forwarding > Lunch or Business Trip
Reactions: rayt and OlegR_3CX
Thanks OlegR_3CX and Dimitris_3CX for your prompt replies.
I suspected Oleg's answer might have been the case, but it appears Dimitris' answer actually works , though I will have to log in as each user to do this. However, this is not a big deal since they are SMB with only 3 users at present .
Cheers guys, keep up the good work .
Reactions: OlegR_3CX
Hello @rayt ,
Oh, I tried your first suggestion without looking at the second. That looks even simpler .
If you navigate to Admin > Users > select user > Call Forwarding you do not have to login with each user so its much more simpler as an administrator.
The first suggestion is if the Users wish to make a name change to the custom statuses.
aatroxadrian
