Solved Renaming of DIDs gone or moved?
kaivonderchromit
sorry for my stupid question, but on releases pre V20.xxx it was possible to rename DIDs Admin->Voice&Chat. Now the names seems the names are fixed or have I overlooked something? A click on the DID just opens a box to edit the DID-number, but I cannot edit the name. Can someone give me a hint, please?
Thank you! Sincerly
Kai
You can try to edit the name when you set the destination of incoming calls:
Thanks for your answer, but unfortunatly it´s not correct, it sets the queue-name, nether a queue or extension is connected to the DID... :(
The pencil next to the DID that has been pointed out to you is where you want to change it..
Oh, sorry Grace Liu and thanks Alphabetic, the pencil was so wide out of my view and it has (so me feeling) nothing to do with the DID ;-) Thank you both a lot!
Seerah Psychology
