Solved Replace License v18 Build 965
clayton.journagan
We are needing to replace the license on our v18 b965 self-hosted (on-prem) Debian install. Before we upgraded to v18 there was a button labeled Replace License Key, but since upgrading we can't seem to find that option. We are wanting to retain the FQDN so before we install a new system we were hoping there would be a better way. Thank You.
Have you enabled the failover option on your installation?
That was the issue. I disabled Failover, and the replace license key option was back. Thank you for your assistance.
I am glad that the issue is now resolved for you.
mazet
