Report
Vineeth Mohan
I need to fetch details from two different reports to one single excel sheet. Both the reports are generated in csv format. Is there a way I can generate the report with the date as the file name. Or put a custom name for the reports.
Now I get file names as ReportName_Date_FE2pAKYbW1kcB9nAhzgU
Hi @Vineeth Mohan,
I'm afraid that reports come as is. When providing the name, it appears as you've mentioned. I'm afraid there is no other way to change it for now.
Silent_Guru
