- Joined
- Oct 10, 2019
- Messages
- 3
- Reaction score
- 0
My CRM integration is working if I run "Report Call" from the Template Generator but if I apply the template to my server, it doesn't work. I also restarted the service "3CX PhoneSystem 01 System Server". How can I troubleshoot from here?
Code:
<?xml version="1.0"?>
<Crm xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Country="US" Name="RepairShopr" Version="1">
<Number Prefix="Off" MaxLength="10" />
<Connection MaxConcurrentRequests="2" />
<Parameters>
<Parameter Name="APIkey" Type="String" Parent="General Configuration" Editor="String" Title="API Key:" />
<Parameter Name="ReportCallEnabled" Type="Boolean" Editor="String" Title="Enable Call Journaling" Default="True" />
<Parameter Name="Domain" Type="String" Editor="String" Title="Domain:" />
</Parameters>
<Authentication Type="Basic">
<Value>[APIkey]:X</Value>
</Authentication>
<Scenarios>
<Scenario Id="" Type="REST">
<Request SkipIf="" Url="https://[Domain].repairshopr.com/api/v1/customers?query=[Number]&api_key=[APIkey]" MessagePasses="1" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Rules>
<Rule Type="Number">customers.phone</Rule>
</Rules>
<Variables>
<Variable Name="ContactID" Path="customers.id">
<Filter />
</Variable>
<Variable Name="FirstName" Path="customers.firstname">
<Filter />
</Variable>
<Variable Name="LastName" Path="customers.lastname">
<Filter />
</Variable>
<Variable Name="CompanyName" Path="customers.business_name">
<Filter />
</Variable>
<Variable Name="Email" Path="customers.email">
<Filter />
</Variable>
<Variable Name="PhoneBusiness" Path="customers.phone">
<Filter />
</Variable>
<Variable Name="PhoneMobile" Path="customers.mobile">
<Filter />
</Variable>
</Variables>
<Outputs Next="" AllowEmpty="false">
<Output Type="ContactID" Passes="1" Value="[ContactID]" />
<Output Type="FirstName" Passes="1" Value="[FirstName]" />
<Output Type="LastName" Passes="1" Value="[LastName]" />
<Output Type="CompanyName" Passes="1" Value="[CompanyName]" />
<Output Type="Email" Passes="1" Value="[Email]" />
<Output Type="PhoneBusiness" Passes="1" Value="[PhoneBusiness]" />
<Output Type="PhoneMobile" Passes="1" Value="[PhoneMobile]" />
<Output Type="ContactUrl" Passes="1" Value="https://[Domain].repairshopr.com/customers/[ContactID]" />
</Outputs>
</Scenario>
<Scenario Id="ReportCall" Type="REST">
<Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Inbound" Url="https://[Domain].repairshopr.com/api/callerid.json/?did=[Number]&api_key=[APIkey]" MessagePasses="1" RequestContentType="application/x-www-form-urlencoded" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Variables />
<Outputs Next="ReportCallMissed" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallMissed" Type="REST">
<Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Missed" Url="https://[Domain].repairshopr.com/api/callerid.json/?did=[Number]&api_key=[APIkey]" MessagePasses="1" RequestContentType="application/x-www-form-urlencoded" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Variables />
<Outputs Next="ReportCallOutbound" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallOutbound" Type="REST">
<Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Outbound" Url="https://[Domain].repairshopr.com/api/callerid.json/?did=[Number]&outbound=true&api_key=[APIkey]" MessagePasses="1" RequestContentType="application/x-www-form-urlencoded" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Variables />
<Outputs Next="ReportCallNotanswered" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallNotanswered" Type="REST">
<Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Notanswered" Url="https://[Domain].repairshopr.com/api/callerid.json/?did=[Number]&outbound=true&api_key=[APIkey]" MessagePasses="1" RequestContentType="application/x-www-form-urlencoded" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Variables />
<Outputs AllowEmpty="false" />
</Scenario>
</Scenarios>
</Crm>
