Solved Reports Menu not available after upgrading from standard to pro license
SebDomSD
The reports menu on the left side is not displayed even if the customer has a pro license.
If I enter the URL manually (https://3cxserver:5001/#/app/call_reports/call_report/), I'm able to reach the report page and options. Although it's possible to create a new report, clicking "Schedule Report" doesn't do anything... Therefore, I cannot schedule any reports.
My customer is running version 16.0.493.
Thanks in advance.
Sebastien
Have you checked the license info within the management console - does it say Pro license,
You could try refreshing the license , to see if this resolves the issue
Yes license is displayed as Pro.
It also says :
3CX Phone System Pro Edition featuresYes
I've even restarted all 3CX services with no avail...
Sebastien
Hi @SebDomSD
Try clearing your browsers cache or try to access the management console from an incognito window.
See if that helps.
ok, it works.
Actually, trying in another InPrivate browser worked. But I finally realized the option is only available when logged as admin in the portal.
I was using my user account that has all privileges but you need to be connected as admin to access reports.
Thanks for your help.
Sebastien
Reactions: YiannisH_3CX
Glad to see the issue has been resolved
Kayla Norris
