Reset PBX and configure Voxbone SIP Trunk
DavidBLg
New User
Hello all,
(I'm new with 3cx PBX)
2 questions in 1, I did a lot of test and tries about connecting my Voxbone SIP Trunk. So my PBX is a bit messy. Is there a way to reset it?
My second point, I did not find any doc or recent thread on how to configure Voxbone SIP Trunk, could someone tell me if there are tricks or specific points with Voxbone?
Thanks in advance!
Hello @DavidEpys
Regarding the first part of the question i would recommend simply re-installing the system to make sure that you have a clean base to work with. It takes very little time to do so.
Regarding Voxbone please note that since they are not a supported provider we have not tested them and cannot provider any guidelines on how to configure them. Perhaps another user who already uses Voxbone can assist with the configuration. I would recommend using one of our supported providers to avoid any compatibility issues.
https://www.3cx.com/partners/sip-trunks/
megalmazan
