Resources normal?
darenfriday
Hey 3CX
Our 3CX sits on Hyper-V VM. 2 Xeon Cores, 8GB RAM but it sits constantly at 50-60% resource use.
Is this normal? The previous version never got above 10% on the same hardware.
Everything is working OK
Just curious
Daren
Need more info on your setup
License - sim call number
Queues used
Number of extensions
Pro licence
16 Sim
No queues
43 extensions
Daren
Hey 3CX
Just curious
Daren
There is a post https://www.3cx.com/community/threads/ent-1024-high-cpu-load-using-web-clients.113032/#post-522547 but not sure it helps.
Wondering if how many Entension up and number of calls in use when you hit this usage?
linux?
What do you see with the "top" command in the linux CLI?
Edvard
