REST API
mr 360
New User
Hi I am a beginer for this 3cx platform,
i could not understand this crm template
but i try create contact via postman rest api but no response here
i am trying this code
method : POST
url : https://myname.3cx.in/api/v2/contacts
what is the way for creating contact and get access tokens,and get contact
please help me
It's not that simple, first in order to get or post you must be logged in to the pbx, to login you send a post request with your admin username and password, this will give you a cookie, now you can make a get or post request. How this is done varies depending on the markup language you are working with. I use PHP and can help you out if you want.
Hi sir ,
get cokie and create contact (ordered)
please send your php code sir
lastshadow
