- Joined
- Jan 22, 2021
- Messages
- 51
- Reaction score
- 8
I have successfully setup the xml template. The flow I have after the Auth was to:
- Lookup the Contacts DB with a "Next=CreateEngagement" attribute (No outputs here).
- The CreateEngagement does a POST request to create an engagement the returns back the data and this is where outputs are added with variables coming from the lookup.
- In the CreateEngagement outputs, there is a ContactUrl where I add a query param setting the value of the "EngagementID" I received from "CreateEngagement".
- The CreateContactRecord is also using the "CreateEngagement" as a Next attribute so it will be executed after the contact is created.
So far, when testing in the management console, everything works. When I lookup and there is a match found, it then creates an engagement in our db and I get a new engagement ID every time I test this in the console. The newly created engagement ID is then set in the ContactUrl ouput as a query param.
The problem is that when testing via an actual call, this engagement ID in the url param does not update. It always uses the initial id during the record creation.
Apologies, hope this make sense. Any help would be much appreciated.
Thanks!
Thanks!
