Reverse from:to display on inbound calls to Yealink
David_K
Hello
Memory leaking, I can't find anymore where to change this.
I have 2 inbound rules for 2 different DIDs
DID1 = CompanyA
DID2 = CompanyB
When someone is calling DID1, on the phones I see for instance "+33142345678:CompanyA" where +33142345678 is the caller.
When someone is calling DID2, on the phones I see for instance "+33142345678:CompanyB" where +33142345678 is the caller.
But when the caller is a long number, I get a scrolling text and need to wait till I know which company is called.
Where can I reverse display to get "CompanyA:33142345678" or "CompanyB:33142345678" ?
(so "to:" displayed before "from:")
Thanks!
Under Contacts - Options - Add Group, Queue or DID/DDI Names to Caller ID Setting
Thanks, that was it :)
Could be better : in fact I've created ring groups. So now it's showing like "RingGroup1:CompanyA:+3312345678"
Is it possible to get rid of the RingGroup1 in front since I have only 1 Ring Group? I don't see the benefit of showing it...
try removing the name in the ring group
[email protected].
