Solved Ring Group Destination if no answer, busy
nfalconepvtwp
I seemingly have the same issue as this person:
https://www.3cx.com/community/threads/disconnects-after-the-second-redirection.129838/
When calling a ring group, after 40 seconds it goes to busy and hangs up, instead of a Digital Assistant. Any ideas?
I've also tried changing it from Destination no answer to Voicemail and still get a busy signal instead of the voicemail.
Our system is on Version 20.0 Update 3 (Build 806 Release)
Have you looked at the 3CX Activity Log (If available, on your version), in Verbose, for clues as to what is happening after the 40 seconds?
Yeah this is all I get:
C:351 Failed to build divert target EndCall.NoAnswer; fail reason = NoAnswerTimeout
That cant be all if your logs are in verbosity
This is what I get
Code:
0/30/2024 4:05:41.977 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] being terminated (Cancelled)
10/30/2024 4:05:41.969 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.8[Extn:496{645aff09bc91}]
10/30/2024 4:05:41.969 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (RouteNotFound) to L:1021.8[Extn:496{645aff09bc91}]
10/30/2024 4:05:41.968 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.8[Extn:496{645aff09bc91}]
10/30/2024 4:05:41.968 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.8[Extn:496{645aff09bc91}]
10/30/2024 4:05:41.968 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.968 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.965 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.7[Extn:403{1d1aab736d31}]
10/30/2024 4:05:41.965 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (RouteNotFound) to L:1021.7[Extn:403{1d1aab736d31}]
10/30/2024 4:05:41.965 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.7[Extn:403{1d1aab736d31}]
10/30/2024 4:05:41.964 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.964 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.962 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.6[Extn:402{c8e9f27aaaa1}]
10/30/2024 4:05:41.962 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (RouteNotFound) to L:1021.6[Extn:402{c8e9f27aaaa1}]
10/30/2024 4:05:41.959 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.6[Extn:402{c8e9f27aaaa1}]
10/30/2024 4:05:41.959 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.6[Extn:402{c8e9f27aaaa1}]
10/30/2024 4:05:41.959 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.959 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.958 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.5[Extn:401{90720f79c2bd}]
10/30/2024 4:05:41.958 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (RouteNotFound) to L:1021.5[Extn:401{90720f79c2bd}]
10/30/2024 4:05:41.958 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.5[Extn:401{90720f79c2bd}]
10/30/2024 4:05:41.958 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.958 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.957 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.957 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.4[RingAll:804{a3d47522f161}]
10/30/2024 4:05:41.957 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.3[Route:GRP0005@{}{2376fe642fdc}]
10/30/2024 4:05:41.957 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.3[Route:GRP0005@{}{2376fe642fdc}]
10/30/2024 4:05:41.956 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] has no segment with L:1021.3[Route:GRP0005@{}{2376fe642fdc}]
10/30/2024 4:05:41.956 PM    L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] segment terminated (Cancelled) to L:1021.3[Route:GRP0005@{}{2376fe642fdc}]
10/30/2024 4:05:41.956 PM    [IncRR](C:1021): On Leg Terminated: L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}]
10/30/2024 4:05:41.956 PM    Segm(5340): L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] reported segment termination (UserTerminated); dest Extn:496{47fb0710bab8}
10/30/2024 4:05:41.956 PM    Segm(5339): L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] reported segment termination (UserTerminated); dest Extn:403{fc8d65425a5c}
10/30/2024 4:05:41.956 PM    Segm(5338): L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] reported segment termination (UserTerminated); dest Extn:402{a91f883b3d3f}
10/30/2024 4:05:41.956 PM    Segm(5337): L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] reported segment termination (UserTerminated); dest Extn:401{3af9206da626}
10/30/2024 4:05:41.956 PM    Segm(5336): L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] reported segment termination (UserTerminated); dest RingAll:804{a3d47522f161}
10/30/2024 4:05:41.956 PM    Segm(5335): L:1021.1[Line:10000<<4403502244{63bd0e3a36b9}] reported segment termination (UserTerminated); dest Route:GRP0005@{}{2376fe642fdc}
Figured it out, ring group was set to ring for 40 seconds, sip provider (Voip.ms) was set to only ring for 30 seconds. Changed it under the DID in VoipMS for 50 seconds and works as it should
Reactions: leejor
tom.walker@blackcountryra
