Ring Group Voicemail Prompt Language V20
VincentDalvani
New User
So I set a department up called "French" changed the prompts to French.
Then I setup a ring group selected the French department and set on no answer go to the voicemail of that ring group.
When I call the ring group the voicemail is in English? Have I missed a step?
Hi there.
Have you opened the ticket with us on this matter to check the logs etc?
Thank you
DrunkeMeister
