Ring Groups to copy Queues
VoipGs
Since the last update the queue functions is gone. I only have 1 agent answering the calls and I was wondering if the usage of ring groups allows to keep the call on hold until an agent is available? In my case I want to keep that call on hold until the agent hangs and is able to answer the next one.
Thanks!
how many SC can you use for now on your 3CX?
The licence allows 8 SC.
Sorry wanted to know about your trunk channels
So, I have 2 trunks with 2 sim calls each enabled.
OK, so you have only one agent to receive 4 calls maxi, am i right?
if so, the best way for you is to update to a pro license to keep Q working as previously, it's not possible to do the same with ring groups in your use.
Ring Groups do not work the same as Queues, if the one user in the ring group is busy, it will flow the 'Destination if no answer' option
If you update your 8SC to Pro there's no settings change to do on your 3CX, just update the license on the MC dashboard.
fransisco
