Ringing multiple IP Phones
siscom
Good Afternoon Colleagues
I hope you are doing well . One of my customers need the following solution:
1) For each floor, He will need five different extensions (for example: 101 , 102 , 103 , 104 , 105) . Those extensions is able to call each others in addition to call extensions in other floors.
2) It is required to have one extension for each floor (for example: 110 for floor 1) . If anyone call this one extension (110 in our case) , all phones in the floor will ring (101 , 102, 103 , 104 , 105) where any of those extensions can pickup the call.
Does the above applicable in standard edition ? If so how many concurrent sessions will be consumed ?
Best Regards
In 3CX you can not ring multiply phones if someone rings one extensions.
What you would do, make 110 a ring group - so that it rings 101, 102, 103 .104 and 105. This is standard function in standard license
Good Afternoon Saqqara
Thx for your replay . So in this case , How many licenses (concurrent sessions) will be consumed ?
Best Regards
A call to a ring group is classified as one concurrent call - it does not matter how many extensions are a member of the group.
If you set a RG for your extensions (101->105) then you don't need to use 110 as RG number but use 3CX system extension number and keep 110 free to use for someone in the company
Thx so much Saqqara
Thx aws2p for your input
DrunkeMeister
