Solved Router Phone - Fanvil V62 not provisioning
mirjam.nz
Hi We have a brand new Fanvil V62 with the correct firmware, trying to setup as RouterPhone on a 3CX hosted V18.
Followed guide but receive an error in the event log:
>> RPS request for Fanvil (MAC:0C38xxxxxxx) IP Phone of SBC Phone (EXTENSION) delivered successfully
3CX Phone System Management Console ID: 10018 05/30/2023 08:23:18 AM
followed by:
>>Invalid RPS key 33089871 provided for extension [EXTENSION]
When I log in to the Fanvil phone, I do find in the Auto provision Tab the information:
Static Provisioning Server >>
Server Address: FQDN
Configuration File Name: rps/[EXTENSION]:33089871/$mac.cfg
Protocol Type: HTTPS
SBC Sip Trunk gets created, but the phone is not provisioning.
We can also access web-client from network where Fanvil phone is located.
- I have deleted the phone from the extension and restarted the 3CX Server.
- Added the client's public IP to the blacklist
- Re-assigned router phone to extension
- Factory reset the Fanvil and restarted
......but no joy either.
Any hints on what's going wrong here would be appreciated.
Miriam
Hi! Is it possible that the extension already has another phone?
After the event entry you've mentioned for successful delivery of RPS request, do you see other entries for RPS delivery related to the same EXTENSION?
@mirjam.nz try to factory reset the phone now without touching anything on 3CX.
@ivank, yes there is another message
Provisioning file xxxxxxxx.cfg requested by [PUBLIC IP PHONE] could not be generated
I have reset everything again and factory reset the phone.
1. Then I created a new user and this did the trick
2. Assigned the MAC address as a router phone to the new extension
And it's working now :))
Reactions: JohnS_3CX
Glad to hear that was resolved @mirjam.nz
Can you also please tell us your 3CX version number?
Hello.
I have a similar problem with a Fanvil V64. Everything works fine when I set up the phone as a router phone connected to the internet via the ethernet LAN port and use the MAC address of the ethernet port. When I restart the phone and connect it to the internet via WiFi, I get SIP Registration Failed error message.
When I try to set up the router phone using the MAC address of the WIFI adapter in the 3CX configuration, I get an invalid RPS key XXXXXXXX for extension XXX error message. It is essential we use WIFI for the phone.
@JohnS_3CX, running 18.0 Update 7 (Build 424)Version, hosted by 3CX
Hello.
We do not test or support WiFi on IP phones - if this is a requirement in this case then you need a different solution.
Teemal
