Router Phone -- Is there an appliance I can use for this?
mgonzalez
I am wondering if instead of a router phone there is an appliance that will only handle the routing?
Im looking for something that has been tested and that would not give me problems once its setup
Some device that I can put in the network closet on the wall or something and do its job.
Thank you for your input..
If you have remote phones, then these must be provisioned behind the 3cx sbc or router phones.
You can install the 3cx sbc using a raspberry pi 5 or a mini pc running linux, for further details check this guide
We've deployed 200+ Raspberry PI's. They have been very stable and work well. I think we've seen maybe 6 failures all due to SD cards failing.
As others have already mentioned, you're describing the exact function of the SBC on whatever hardware you choose.
x1515
