Routing call using bridge
rclocherty
Hi all
I am not 100% sure if this is possible or not but we currently have multiple 3CX instances located all over the world with different SIP trunks on each one. For my example I will use my UK & Germany sites.
Curently we make alot of expensive calls from the UK to Germany using the UK PBX & SIP, my question is... is it possible for us to bridge the UK to Germany then have a rule in place on the UK PBX that any call starting +49 routes to the Germany PBX via the bridge and then completes the call locally therefore utilising the local German SIP trunk & lower call charges?
I have the Bridge in place so far which works and i have tried a few different rules on the German PBX but canno seem to get the call to complete.
Thanks!
You need to route the outbound rule for your +49 to the bridge, and on the other side you need to have an outbound rule that will take that +49 and dial it. No filters on the rule on the UK PBX, otherwise it won't route correctly.
By default, bridges take the dialed number and routes it like it would be dialed from a registered phone. Thus how we can route through another PBX.
Reactions: jed
youwillbrun
