Routing Issue
Dadgey
This is in a paid licenced self hosted version, not sure why I can only see 4SC FREE forum but anyway I'm sure that won't matter for the issue ....
I'm having a issue routing calls with Ring groups.
Call comes in and is routed via Incoming Rule to Ring Group #1 after 30 seconds this should Move to Ring Group #2, after another 30 seconds this should move to a users voicemail.
Issue
After the 30 seconds on Ring Group 1 call is ending, without ever reaching Ring Group #2. Error on an iphone shows "User busy". I believe this was previously working without anything having been changed.
Which should overflow to this ...
Any help appreciated.
Log details here, if they're of any help ...
10/25/2024 12:52:37 PM - Leg L:22.5[Extn:604] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
10/25/2024 12:52:37 PM - [CM503003]: Call(C:22): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
10/25/2024 12:52:37 PM - Leg L:22.6[Extn:604] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 12:52:37 PM - [CM503003]: Call(C:22): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 12:52:37 PM - Leg L:22.4[Extn:603] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 12:52:37 PM - Leg L:22.3[Extn:600] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 12:52:37 PM - [CM503008]: Call(C:22): Call is terminated
10/25/2024 12:52:37 PM - Leg L:22.1[Line:10004<<XXXXXXXXXX] is terminated: Cause: CANCEL from XXXXXXXXXX:5060
10/25/2024 12:52:27 PM - [CM503002]: Call(C:22): Alerting Extn:604 by contact <sip:[email protected]:5063/UDP>
10/25/2024 12:52:27 PM - [CM503002]: Call(C:22): Alerting Extn:604 by contact <sip:[email protected]:5483/UDP>
10/25/2024 12:52:27 PM - [CM503002]: Call(C:22): Alerting Extn:603 by contact <sip:[email protected]:5483/UDP>
10/25/2024 12:52:27 PM - [CM503002]: Call(C:22): Alerting Extn:600 by contact <sip:[email protected]:5483/UDP>
10/25/2024 12:52:27 PM - Leg L:22.2[Extn:600] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 12:52:27 PM - [Flow] No office hours set, office hours assumed
10/25/2024 12:52:27 PM - [Flow] Target endpoint for 600 is Extn:600
10/25/2024 12:52:27 PM - L:22.1[Line:10004<<XXXXXXXXXX] forwards call from RingAll:809 to RingAll:810 based on rule
10/25/2024 12:52:27 PM - [Flow] Target endpoint for 810 is RingAll:810
10/25/2024 12:52:27 PM - L:22.1[Line:10004<<XXXXXXXXXX] failed to reach RingAll:809, reason No Answer
10/25/2024 12:51:57 PM - [CM503002]: Call(C:22): Alerting Extn:600 by contact <sip:[email protected]:5483/UDP>
10/25/2024 12:51:57 PM - [Flow] Target endpoint for 600 is Extn:600
10/25/2024 12:51:57 PM - [Flow] Call(C:22): has built target endpoint: RingAll:809 for call from L:22.1[Line:10004<<XXXXXXXXXX]
10/25/2024 12:51:57 PM - [Flow] Target endpoint for 809 is RingAll:809
10/25/2024 12:51:57 PM - [CM503010]: Call(C:22): Making route(s) from Line:10004<<XXXXXXXXXX to <sip:809@XXXXXXXXXX:5060/UDP>
10/25/2024 12:51:57 PM - [CM503001]: Call(C:22): Incoming call from Line:10004<<XXXXXXXXXX to <sip:809@XXXXXXXXXX:5060>
10/25/2024 12:51:57 PM - Line limit check: Current # of calls for line Lc:10004(@TP2 SIP Trunk[<sip:10004@XXXXXXXXXX:0/UDP>]) is 1; limit is 2
10/25/2024 12:51:57 PM - [CM503012]: Inbound office hours rule (unnamed) for 10004 forwards to DN:809
10/25/2024 12:51:57 PM - [Flow] Looking for inbound target: called=+XXXXXXXXXX; caller="XXXXXXXXXX" <sip:XXXXXXXXXX@:0>
assume this says call was terminated from your sip provider?
Are you not using a supported sip provider? Have you got supports reinvite enabled on sip trunk?
Not supported. I can confirm the CANCEL has come from the SIP Server.
What if one of the extensions in the Ring Group had DND set. Would this cause it to fail also?
No it wouldnt.
Is support reinivites enabled on the sip trunk?
It is not, no.
Nope still drops same error.
10/25/2024 4:50:35 PM - Leg L:27.5[Extn:604] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
10/25/2024 4:50:35 PM - [CM503003]: Call(C:27): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
10/25/2024 4:50:35 PM - Leg L:27.6[Extn:604] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 4:50:35 PM - [CM503003]: Call(C:27): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 4:50:35 PM - Leg L:27.4[Extn:603] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 4:50:35 PM - Leg L:27.3[Extn:600] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
10/25/2024 4:50:35 PM - [CM503008]: Call(C:27): Call is terminated
10/25/2024 4:50:35 PM - Leg L:27.1[Line:10004<<xxx is terminated: Cause: CANCEL from sip server:5060
LeeonLau
