Run update on 3CX Raspberry instance?
JC2022
New User
Hi, it says 'Update 3 unavailable on Raspberry Pi PBX
Raspberry is undergoing some changes which will bring future builds of its operating system in line with Debian. When 3CX supports Debian 11 (bullseye) we will look at supporting Raspberry once again. For the moment update 3 will not be available for Raspberry Pi.'
Looks like I cannot update to 3 Final on my Raspberry...
But, my question is; am I OK to run sudo apt update and sudo apt full-upgrade from the terminal on the Raspberry?
Update 3 was the first to remove Pi support.
re: updates, 3CX's advice is to not manually install any updates to the OS, to avoid breaking any dependencies. Enable automatic updates in 3CX, and 3CX will install any needed updates. (manual updates won't install OS updates).
Got it, thanks.
martin1176
