Solved SA Web trunk
devlin
Busy with a Web trunk setup, IP Based. I am not sure of the correct configuration. We have an account ID as an IP address say 10.x.x.x, we have a network space 197.x.x.x/29, GW 197.x.x.1 and SBC Access IP 197.x.x.x.
I have tried many different variations of the IPs with the ID, GW and Access IP.
Sound like you need split networking for that provider, which is not easy if you're system is cloud.
Reactions: devlin
No eventually got it right, literally 5 minutes after this. SIP trunk name 10.x.x.x SBC access ID 197.x.x.x as gateway address. Which I had setup correctly but they use the DID's given as their authentication. After adding the CLI to my ext it called out.
lastshadow
