Solved salefoforce integration
gintronic
hello i've done saleforce integration as the guide but when i push the button "Autorize" this error occur
"state": [
"The state field is required."
what is my mystake?
Thank you for you support
Nicola
The state is provided by 3CX when doing the authorization. Most probably the app you created in Salesforce is not following the guidelines described here. Please ensure that you're following that guide to the letter, with every permission exactly as described.
Something has been misconfigured. Ensure that all steps as per guideline are followed in order as they appear.
thank you i've found that in the salesforce config was missing :5001 tcp port in the string
now all is working as expected
Finatra.us
