Salesforce automation on popup new contact and create new contact inbound call
roiya
Gold Partner
Since there is no valid match returned from the CRM (non existing contact) it is expected that there will be no pop-up.
You will need to manually create the contact from the Web Client. You will see an "Add contact" link, from which you can open a dialog, fill the contact name, and create the contact in Salesforce.
Tried my luck to understand if there is an automation for that .
But TY for answers :)
Reactions: TheodorosG_3CX
There is a way if you modify the XML template, but it requires some knowledge.
