Salesforce Call Journaling Issue
Jalobken
Trial User
Hi All,
I am having an issue creating call journaling in Salesforce, I have followed the guide and this has been connected, however when I make a call I get the link into Salesforce, and when answering I get navigated to Salesforce - but the call doesn't log at all, below are the test results.
Finished Auth
Request text: https://**Correct Value**.my.salesforce.com
Response text: {"searchRecords":[{"attributes":{"type":"Contact","url":"/services/data/v55.0/sobjects/Contact/**Correct Value**"},"Id":"**Correct Value**","FirstName":"**Correct Value**","**Correct Value**":"**Correct Value**","Title":"**Correct Value**","Department":"**Correct Value**","HomePhone":null,"MobilePhone":"**Correct Value**","Phone":"**Correct Value**","Email":"**Correct Value**","AccountId":"**Correct Value**"}]}
Response finished
Variable Id set to **Correct Value**
Variable EntityType set to Contact
Variable FirstName set to **Correct Value**
Variable LastName set to **Correct Value**
Variable Title set to **Correct Value**
Variable Department set to **Correct Value**
Variable Phone set to **Correct Value**
Variable MobilePhone set to **Correct Value**
Variable HomePhone set to
Variable Email set to **Correct Value**
Variable AccountId set to **Correct Value**
Started GetAccountName
Response text: {"totalSize":1,"done":true,"records":[{"attributes":{"type":"Account","url":"/services/data/v55.0/sobjects/Account**Correct Value**"},"Name":"**Correct Value**"}]}
Response finished
Variable AccName set to **Correct Value**
Finished GetAccountName
Finished scenario with empty id
Result obtained
You need to enable verbose logs in 3CX, then make a test call, and check the 3cxSystemService.log. That file will give you the details of the interactions between 3CX and Salesforce, any error will be visible there.
Reactions: jed and Evolute IT
Thanks for the response Ernesto, however upon turning on verbose logging, the response was 350 + lines, and whilst I did try and look through, nothing popped out as an error.
Is there anything specific I should be looking for?
Check for lines starting with "CRM:", that's the prefix for all CRM logs. This might not be shown as an error, but checking the JSON sent and the response received back will give you an idea.
Diogo Maia
