Sangoma S505 HTek 924 Template Compatibility
kriley87
Hi there-
Can anyone confirm if the Sangoma S505 phones will work on 3CX using the HTek 924 template? They are essentially the same exact phones to my knowledge but I'm curious if anyone has made this work in production? Trying to do some data gathering while I decide if moving 25+ of these phones over to a 3CX installation is viable.
Thank you!
Update: I have a test device and can confirm the HTek 924 template works with the Sangoma S505.. the device registered and I was able to program some BLF and call parking keys, tested inbound and outbound, etc.. I'll spend some more time on this but it appears to work.
Thanks for the feedback. Are you able to flash the stock Htek firmware or are you using the Sangoma firmware?
Innovative Advisory
