SBC BLF limit
Justin D
I'm about to implement a Raspberry Pi 3 B+ SBC and I've just noticed that it says a maximum of 20 phones and 10 BLF's per device.
We have 4 x Fanvil X6's that have 24 BLF buttons, of which we would only be using 6 as BLF fields as the rest would be custom speed dials.
I'm assuming when it says maximum 10 BLF fields it means 10 being used as busy lamp fields and not a limitation on the amount of buttons we could use?
Will we have any problems with this setup? (I trust that the above made sense?)
Hello @Justin D
Please note that the limitation is for BLF buttons actually used not what the phone is capable of so you should have no issues with the configuration. Also as you only have 4 phones even if you used all the BLF buttons available then you still would have any issues.
Many thanks for clarifying Yiannis.
Glad i could assist
Zexus
