SBC HA Authentication ID
juice1
New User
Trying to set up the SBC HA cluster.
Can someone confirm this - You use the same “Authentication Key ID” to configure SBC 1 and SBC 2
I cannot see anywhere to edit the ID to make them the same, or is it saying you use the same SBC under 3CX to configure both SBC's?
Have tried with both SBC pointing at the same SBC configured within 3CX and therefire the same ID.....see if that works.....
Hi! You should use the same Auth ID on both installations.
The differences start after the wizard asks you of you want to set it up in HA.
florentrobineau
