Solved SBC Installation Error
gjassal
On the website it is with https, however just tried with http and the link you provided and still same error.
this is copy from 3cx documentation online, perhaps doc is not up to date
Have you correctly configured your TCP/IP settings and DNS on the Pi?
Are you able to ping downloads-global.3cx.com
Yes, i can ping it fine.
Is there a key i need to download?
It seems you are not able to resolve the downloads server due to a network or DNS error at your end most likely.
I can confirm it works from here, just ran the installer as per the guide and completed successfully
Thanks everyone!
It was my firewall blocking it...
Reactions: AWS2P
Kayla Norris
