Solved SBC installer for V20
LRITSDM
Forum User
Reactions: DimitrisL_3CX
Is the port correct on the provisioning URL? Can you at least connect if you browse to it from that PC?
Follow the instructions to a tee.
Check your firewall test comes back green.
Hello @LRITSDM,
Are you referring to a SMB installation? If yes then please note that the ports are already open.
Please double check that the Authedication ID and the provisioning URL are correct.
If this for an on-premise instance then make sure that the ports are open as per our guide Firewall & Router Configuration
Found the issue, the public IP had been blocked due to some failed connection attempts.
Unblocked and install went through with no issue.
Thank you everyone for the quick responses.
Isuru Eranga
