Solved SBC RaspPi 3
AEGIS_SEC_SOL
I have a raspberry pi 3 that was on V16, I created a fresh install with V18. what is the easiest way to configure it for V18 new instance.
By fresh install do you mean you did not restore a v16 backup? I'm asking because had you done so, you should've still been able to see the SBC in the PBX SIP Trunks section.
If you have not restored a backup you will have to re-install the SBC. Create the SBC entry on the PBX in the SIP Trunks section and then do the following:
If running Debian 9 for Raspberry try:
• SSH to the Pi
• Run the following one-by-one:
sudo apt remove 3cxsbc --purge
sudo apt autoremove
sudo apt autoclean
sudo apt update
• Proceed with the installation.
If running Debian 10 for Raspberry try:
sudo apt autoremove
sudo apt autoclean
sudo apt update
If you face any issues with the above, you might want to consider re-flashing the SD with Debian 10 for Pi and configuring the OS and the SBC from scratch: https://www.3cx.com/docs/installing-pbx-raspberry-pi/
Thank you. I went ahead and upgraded to Raspberry pi 4, so that it is easier for future upgrades.
Reactions: ChrisC_3CX
Good call!
As this seems to be sorted I'll be marking it as solved!
Do let us know if you need anything else!
