sbc to Raspbian Stretch image
Easy Data
Hello all. I have a 3cx pro ver 16.02.910 installation setup with 4-5 windows SBCs across country and everything works Fine.
Last days i bought a Raspberry Pi 3 and followed the instructions from https://www.3cx.com/docs/installing-pbx-raspberry-pi/ to install Raspbian Stretch image so far so good BUT
Everytime i try to install SBC (wget http://downloads.3cx.com/downloads/sbc/3cxsbc.zip -O- | sudo bash) and connect it with the customers site it gives me the SAME error (even with my 3cx tryed as well) , error says the authendication KEY is invalid even it is the correct key as i copied from sip trunk sbc settings. What can i do ???
Every other "old" sbc from windows works fine (the key is differnt there from settings-> security-> 3cx tunnel)
Thank you!
Thank you step 2 is already configured thats where i took the key
bosdorf
