SBC Update not working
simply7
I have a few SBC's that won't update. Currently running 18.0.30 on them. Tried running sudo apt update but when it gets to http://downloads-global.3cx.com/downloads/debian -testing Release - I get 404 Not Found [IP:172.67.39.236 80]
then the error
E: The repository 'http://downloads-global.3cx.com/downloads/debian -testing Release' does nto have a Release file.
Anyone have any thoughts on this one? Hitting update in the management console yeilds no results. I can ping the IP listed above just fine.
Can you go to /etc/apt/sources.list.d and look what's in both 3cxpbx.list and 3cxpbx-testing.list
In mine, I have the following:
3cxpbx.list
Code:
deb http://downloads-global.3cx.com/downloads/debian buster main
3cxpbx-testing.list
Code:
deb [arch=armhf] http://downloads-global.3cx.com/downloads/debian buster-testing main
If this doesnt sort it then i'd just reinstall the SBC.
Just want to point out the following:
• If you're running Debian 9 then you'll need to replace "Buster" with "Stretch"
• The 3CX SBC you're currently running is the latest stable one so I'd actually recommend staying on that version for now especially if it's a production system.
megalmazan
