SBC update showing beta even though Final is available.
ebrowne_sts
Platinum Partner
SBC Build 18.1.36 FINAL is already out, but when going to update the SBCs, only 18.1.34 beta shows. Do I have to install the beta before I can get to the Final?
It may have something to do with the sources being old. I ssh'd in and ran a sudo apt update then sudo apt install --only-upgrade 3cxsbc and was able to update to 18.1.36.
martin1176
