Scheduled Backups not working
DaveA66
Platinum Partner
I have noticed that our scheduled backups to a Google cloud bucket stopped working on 31st May.
I can do a manual backup to the same location with no problem.
I have tried to find some information in the logs as to why it's failing but couldn't see any backup related info at all.
Could someone point me to the right log file please?
many thanks!
What does the email log say?
Can't find a log related to email?
Not the email log
Have you received an email with info about the backup and why it failed. Email should goto the recipient under Settongs - Email Settings - Notifications
Is the time correct on your machine?
The date and time look correct.
Email notification for backups are off, so will enable and see what it says tonight!
many thanks
So I enabled the email notification however it looks like you only get a notification on a successful backup, not a failed one, which is back to front in my opinion. Any pointes as to which log file I can check?
Thanks!
Silent_Guru
