Solved Screen sharing does not work
VSC
Forum User
Some users that use Chrome Version 98.0.4758.102 are not able to share their screen because the menu is empty. I am using the same version and it is working fine. Also they can share their screen if they use the 3CX Desktop App or Edge.
Hi @VSC,
I tried to reproduce this, but wasn't able to. Is there anything they're doing differently to you when joining / setting up the meeting that we can try to replicate it? For now, I can tell you that WebMeeting is working fine on my side without issue.
Have they tried to join using an Incognito Window in Google Chrome?
I was sitting beside those users and can tell you that they do it exactly the same I do it. Anything else I can provide to support root cause analysis?
Hi @VSC,
How many users is this happening to?
Have you tried to join the meeting in incognito mode?
One user reported that it works fine if he uses the incognito mode. Next we try to clear cache, cookies and deactivate add-ons. Maybe this way we could get further.
Reactions: VasilisV_3CX
Hi @VSC,
Keep me posted, yes testing with an entirely clean browser would be a great first step. Great to hear it works in incognito mode!
We found the reason for this problem. We are using an add blocker on our clients (https://adblockplus.org/en/download). If someone goes to settings and activates the checkbox "block tracking by social media symbols" then you are not able to share your screen.
To me it seems to be an issue of the add blocker as the symbols shown in 3CX are no social media symbols but maybe they have a special tag or property that makes the add blocker belive it is a social media symbol.
Reactions: NickD_3CX
Hi @VSC,
Great to hear that you found the solution! Feel free to open a new thread if you require anything else.
Graham Robertson
