Secure call
ArthurTen
Platinum Partner
I have question, is it possible to secure a call on softphone that i couldn't see in wireshark packets like TLS Protocol?
13935 13936
Looks to be a yes
If you use the tunnel for the soft phone that will also encrypt it without having to select TLS. But that's only going to secure the softphone to PBX leg of the call.
Yes there is a TLS protocol but I asked wrongly. I mean something like TLS , because 3cx not supporting android 3cx app TLS calls.
And i need to encrypt/secure calls.
And is it possible to make a secure/crypted call with 3cx android app calls
3CX mobile app on Android can/should use the tunnel. The tunnel is encrypted by default in latest versions of the app.
That's just to the PBX, from the PBX to the SIP server may still be open.
so I understand , that if VOIP provider supports TLS encrypted/secured calls then the whole distance will be encrypted?
Unless there's a third leg of the call somewhere you aren't describing but yes most calls will have 2 legs. Client to PBX, PBX to Dial Tone provider (VoIP in this case). If you encrypt both then yes
No need for TLS anyway, the tunnel already takes care of that.
Is the root cert in the trusted roots on the mobile device? I.E. if you are using a cert from Globalsign, is the globalsign root cert in the CA on the device?
Is the intermediate cert in the chain?
3K8iMGWviZ
